Here is yet another "If I can do this, ANYONE can do this" thread on how to install a rear 12V outlet. This is a detailed thread with a lot of pics. The complete beginner who has never picked up a wrench should be able to do the install with complete confidence if you follow this thread's instructions. Because there are so many pics, this thread will be broken up over 3 to 4 posts.
Ok, let's get started. Open the rear door of the FJ Cruiser. If you do not have a 110 converter plug in the rear, then yours should look like this:
It's that little "almost" square cover we will be working with. Now, get a small flat-blade screwdriver, and pull the little cover off....it just snaps off at the top, and pull away:
Now, pull off the larger cover just forward of the small cover:
We are ready to begin, and are at the "point of no return. Once you drill into the cover, you can't go back
Continued in next post....
