Copied from Toyota's Accessories Sales Guide:
Cold Air Intake, TRD, 4.0L V6 PN: PTR05-35061
- A unique 3-angle 5.5" to 4" filter flow adapter mounted in a black rotational-molded housing with a brushed-finish aluminum cover - 4 inch diameter rotational-molded intake tube transitioning to a 3" diameter at the throttle body to maximize air flow into the engine while maintaining correct air/fuel ratio calibration. - A reusable high-flow, low restriction air filter. - All testing done to stringent Toyota standards. Peak to Peak Power Gain HP +11HP @ 4,850rpm; Torque +19.0 ft-lbs @ 3,600rpm - - - Largest Power Gain HP +15HP @ 3,150 rpm; Torque +25 ft-lbs @ 3,150 rpm As tested on 06MY Tacoma. Individual performance improvements may vary. - For race only, the part is not emissions legal.
Last Modified: 05/27/2008
Live Date: 10/19/2006 Expiration Date: -
Note: For race only, the part is not CARB approved. This part is sold with no warranty and installation of this part may adversely affect the warranty coverage of the vehicle. The part is not compatiable with the TRD Supercharger PTR29-35070.
Says it plain...........not emmissions legal!
