For some of you running large tires and a spare 305, 34, or 35" sizes and are having fitment issues on your stock bumper and don't have the coin to buy a new rear bumper. Here is a sweet deal to fix for your fitment or rubbing issues with large rear tires. Very inovating design also.
Warrior Products introduces a handy new bracket that allows extra clearance for mounting larger spare tires. As an added bonus, the bracket can be mounted in several different positions that shift the tire location by up to 1" up, down, or to the side relative to the factory mount. It's constructed from heavy duty steel and powder coated black for long lasting durability and good looks.
Actual spacing will vary on the different brackets from 1.5" to 2" toward the rear. While they are designed on the vehicles they are listed to fit, all of these brackets could be used on any spare tire mount with the matching bolt pattern and the ability to accept the bracket in the available space.
Note: The new 6x5.5" spacer has metric studs. If you're planning on using this with a vehicle that has standard studs, you will need to get new metric lugnuts to hold the tire to the studs.
http://www.warriorproducts.com/catalog/hotspot3.php Cheers!
