Status
Not open for further replies.
1 - 2 of 2 Posts
VIAIR 450P-Automatic
I have two of these compressors available. (NEVER BEEN USED) $250.00 (ea) plus shipping if required. This is one of the top of the line in portable compressors. It could be modified for hard mounting as well.
450P-Automatic is VIAIR's first 100% duty cycle portable compressor. This compressor can run for hours at a time without needing to be rested when run to pressures under 100 PSI. The 450-P Automatic comes with another first as well - automatic shutoff function, when air is not being pumped into a tire and the units air line contains 150 PSI. The 450P-Automatic comes with a close-ended gas station-style air gun for added convenience.
450P-A Standard Features:
• Oil-less Design
• High Performance PTFE Piston Ring
• Stainless Steel Valves
• Moisture & Dust Resistant
• Gearless Direct Drive Motor
• Anodized Aluminum Alloy Cylinder
• Automatic Reset Thermal Overload Protector
• Dual-Stage Metal Air Filter
• Aluminum Sand Tray with Vibration Isolators
• Deluxe Dual Compartment Carry Bag
• 3-pc. Inflation Tips Kit
• 25 ft. Quick Connect Extension Hose with Heat Shield
• Gas Station-Style Tire Gun with 200 PSI Gauge
• Dual Battery Clamps with 40-amp Inline Fuse Holder
450P-A Tire Inflation Rates
31" X 10.5" (15psi to 30psi / 2 Min. 10Sec.)
33" X 12.5" (15psi to 30psi / 2 Min. 50 Sec.)
35" X 12.5" (15psi to 30psi / 3 Min. 30 Sec.)
AMP Draw at 150 PSI = 18-Amp
1 - 2 of 2 Posts
Status
