Yes, forgot to let you all know. I disconnected the battery once I got home and reset the codes. It went away for the time being. THANKS!.Start simple unplug your battery and step on the brake pedal for 10 seconds or so then hook up the battery again. See if the lights stay out. Sometimes the computer just has a hicup and there is actually nothing wrong. I have done this a couple times over the last 7 years and the lights never come back on. If they pop back on then take it in for warrenty work since you only have 4K + miles on the thing![]()
And chances are it will come back. Disconnecting the battery is a temporary fix. If in fact the problem is fixed you need to drive the car for approximately 50 miles and the light will go away. I have changed my mass airflow sensor, fuel tank cap, temperature sensor, air filter, cleaned that charcoal box and the light is on and continue to say error 102, mas. Now I just drive with the warning lights on.Yes, forgot to let you all know. I disconnected the battery once I got home and reset the codes. It went away for the time being. THANKS!.
