Discussion Starter · #1 · (Edited)
I know many people tighten nuts and bolts just by feel and experience. But I was curious and thought I'd put together a collection of torque specs from the '07 FJ Cruiser Repair Manual and keep it in the garage and in the truck for quick reference. I've found that I tend to over-tighten things doing it just by feel. If this list is missing any other commonly used specs, please let me know.
2007 TOYOTA FJ CRUISER
REPAIR MANUAL
TORQUE SPECIFICATIONS
FRONT
TORQUE (ft*lbf)
Axle hub + drive shaft (CV axle), nut
174
Brake caliper assembly + knuckle, bolts
91
Coil-over top nuts
47
Coil-over bottom bolt/nut
100
Differential breather hose + diff carrier
10
Ignition coil + cylinder head cover
7.4
LCA + frame
100
Lower ball joint attachment + LCA, castle nut
103
Lower ball joint attachment + knuckle, bolts
118
Oil, AT, drain plug
21
Oil, AT, fill plug
29
Oil, differential, drain plug
48
Oil, differential, fill plug
29
Oil, motor, drain plug
30
Oil, transfer case, fill and drain plugs
27
Propeller shaft + front differential carrier
65
Propeller shaft + transfer
65
Pulley, Idler, No. 1
40
Pulley, Idler, No. 2
29
Spark plug + cylinder head
15
Sway bar link + knuckle, bolt
52
Sway bar + link, nut
52
Tie rod, inner + steering rack
76 (72 with SST)
Tie rod, jam nut
65
Tie rod, outer + knuckle, castle nut
67
UCA + knuckle, castle nut
81
UCA + frame, bolt/nut
85
Wheel lug nuts
82
REAR
TORQUE (ft*lbf)
Axle shaft + axle housing assembly
89
Brake cylinder mounting + axle
78
Brake cylinder assembly + mounting
65
Link, upper + frame
59
Link, upper + axle
59
Link, lower + frame
96
Link, lower + axle
96
Oil, differential, drain and fill plugs
36
Panhard bar + frame
96
Panhard bar + axle
96
Propeller shaft + rear differential carrier
65
65
Shock bottom bolt
72
Sway bar bracket + axle, bolts
22
Sway bar + link
52
Sway bar link + frame
11
Spare tire wheel lug nuts
65
Wheel lug nuts
82
Your chart is the bomb. Thank you Doug. I'm out now double checking all my rear end components. Should be a firmer seat of the pants feeling since I backed everything off to 60lbs. Don't do it. To sloppy and clunky for day to day.
