1 - 2 of 2 Posts
I purchased my new Treadwrights Warden about a month ago 285/70R17 with new wheels from BBWheels. I used Bead Balancers from Counteract 6oz each for each tire. My FJ was still vibrating, I called Counteract and they told me to put 4oz more on each tire since I was running ATs. I'm still having a slight vibration on my steeringwheel. Has anyone had issues balancing Treadwrights tires? What do you recommend?
If your feeling any vibration in your steering wheel it could be you through a weight... depending on what type of rims you are running weights tend to fly off, also when I did a speed" balance the vibration completely went away it took the tech 3 tries 2 more times going back to the tire shop before they got it right but probable solved no more shaking... I did her the balancing weights come off and hit the bottom of my truck... just FYI.
1 - 2 of 2 Posts
