"Armadillo" - spanish for Little Armored One. Prolific diggers, armadillos have a preference to reside in moist soil near creeks and streams. The are also said to have poor vision but are not blind (FJ pun intended). The armadillo is an animal common to my state of birth, Texas. Growing up, I've always held this small animal with high respect for its habitat and resiliency.
Now, on to the buildup...I have put off creating one for a fair amount of time, mainly out of sheer laziness. However, I've found the constant modding to dictate the need for a journal or record keeping of the Armadillo's progress. She has been purpose built - for years now, I've been trying to convince my wife to move out of SoCal. Specifically, the Pacific NW. Family commitments have made this difficult, and the FJ has served as a blessing. With her, like the armadillo, I practice the art of escapology, eluding predators (the grind, city, pollution, traffic) by scurrying into thick brush, rocks, or digging in mud.
The Purchase
After a grueling decision between another 4Runner (wife drives an 07), a Tacoma, and the FJ - between new versus used, I found the perfect vehicle in November 2007. A Certified Pre-Owned FJ, with all the features I wanted (rear diff locker, side curtain air bags), and none that I didn't. She had 40K on the odometer, and a thorough inspection showed that she had never seen anything but pavement. That changed quickly, as well as her transformation.
Engine
AFE CAI w/standard filter, plug, and pre-filter (sound clip)
AFE Catback Exhaust (pic) (sound clip)
Suspension
OME 886 w/N140S
All Pro Sway Bar Links
Fastenal SS Sway Bar Collars (details)
OME 895 w/N71E
All Pro Ultimate Lower Control Arms
Tires and Wheels
Pro Comp 7089s
Hankook Dynapro MTs 285/70/17
Lights/Switches
PIAA 580s (x2) on All Pro front bumper (pic)
PIAA 540s (x4) on All Pro Air Dam w/Light bar (pic) (pic)
Northern Tool 55W (x2) for front rock lights (details) (pic) (pic) (pic)
Northern Tool 55W (x4) for rear roof rack and rock lights (TBI) (details)
Sylvania XtraVision headlamp
Hella Tacoma OEM switches (details) (pic) (pic)
Armor
Rasta 4x4 full aluminum skids
All Pro front bumper w/large hoop - Line-X'd
All Pro rear bumper w/hitch
All Pro rock sliders
All Pro lower link skids
All Phase rear differential skid
Overland XT (Cowboy4x4) rear lower shock skids
Electronics
Midland 75-822 CB w/Walcott and Bandi mount setup
Radio Shack 72" CB Whip Antenna
12v outlet in center tray
12v outlet on passenger side of center console
12v outlet (x2) in rear cargo area where power invertor would be
Waeco CoolFreeze CF-50 portable fridge/freezer (pic) (pic)
Blue Sea 5025 6 circuit fuse block in passenger kick panel
Blue Sea 5025 6 circuit fuse block in rear cargo compartment
Blue Sea 9004e w/AFO for winch power disconnect
Dirty Parts dual battery kit w/Optima Yellowtop
Master Flow MF-1050 portable air compressor
Viair 450c constant duty on board air w/2.5g tank (pic) (pic) (pic)
Recovery Gear
Warn M8000 winch
100ft Viking Trail Line 5/16" w/safety himble and 10' line protector
Aluminum hawse fairlead
48" Hi-Lift
Hi-Lift base
Hi-Lift isolator
Wab Fab Hi-Lift tube adapter
ARB Bushranger X-Jack (pic)
ARB snatch block
ARB tire deflator
ARB tire repair kit
3/4 ton d-shackles (x3)
12' tree saver
30' snatch strap
Trail Gear
Fire Extinguisher
First aid kit
Tire gauge
Heavy duty gloves
Tool set
Spare Fuses
Duct tape
Zip Ties
Hose Clamps
Heavy duty knife
Rope
Flashlight
Engine Oil
Brake Fluid
ATF
Jumper cables
FRS/GMRS
Toilet Paper
Garbage bags
WD-40 or equivalent lubricant
Emergency window breakage/seatbelt cutting tool
Fuel Cans
Quicksteel or JB Weld
Blankets
Axe/Shovel
Gear oil
Grease
Brake cleaner
Goop/Hand cleaner
Signal flares
GPS
Compass/Maps
Waterproof matches/lighter
Ratchets/tie downs
Additional tools - Breaker bar, Torque wrench, slide hammer, 35mm socket, Hacksaw or cutting device, vise grips, etc
Spare parts – CV axle, CV boot, tie rod, sway bar link, rear LCA
Misc Mods
Euro military surplus fuel cans (x2) mounted on rooftop
1.75" clamps for Hi-Lift mount
1.75" clamps and u-bolts for Coleman Safari basket mount (pic) (pic)
1.75" clamps and quickfists for axe/shovel mount (pic)
A-TRAC button
A-TRAC and Rear Diff hack
Rear Diff and E-Locker breather scuba mod
2008 Side Visors
Black Tundra door handles
Painted front bezel black
BD Hood with lower TI trim
