How do I get the E-brake to release enough to remove the rear rotors?
Thanks for your help.
Yea, there is a slight taper to the hub. It's kinda hard to explain. The rear rotor is kind of a hybrid setup. The e-brake works like a traditional drum brake. It has two shoes on the inside of the rotor/drum. It adjust just like a set of drum brakes.Is the rotor tapered to the hub then?
Wanted to!Doug,
When in doubt..... use a sledge hammer.
Not a discernable taper. Was so easy to remove after the E-brake let go.Is the rotor tapered to the hub then?
Yea, common but when most people pull off a rear wheel and see a disk brake, you don't think about it having shoes inside for the e-brake. Glad I could help!!Funny thing, at dinner with the parents, my father said it's common knowledge that you can adjust the brakeshoes through a hole on the rotor, if you've ever worked on drum brakes before. Hahaha .... neither my buddy nor I have.
Would love to go to Welks but no sliders yet. Tires this week and sliders in a few.Nos2fly, you rock. I even want to think you pulled your hardware just to attach pics. Are you going to Welks?
I know this is an OLD thread, but I found it in a search as many of you might. The information above was reversed for my 2007 FJ. I had to turn the little wheel down to contract the brake shoes, to get the rotor off. Just wanted to pass that on to hopefully help anyone else.With a
screwdriver, you can turn it upwards or downwards. Up is to contract the
brakeshoes, down is to expand.
