1 - 12 of 12 Posts
I have the Demello High Lift mounts and the Four Trek Tool mounts... went to set everything up on Moby and...
Demello has the instructions for installation on the drivers side for the high lift. This is because if the mounts are on the passenger side the jack has to sit back further to clear the "jack" mechanism. So that got me thinking...
Why do you mount your jack on the drivers side or passenger side? ???
I'm more curious than anything...
I thinks its really about what works, and what people want.
I am using some U bolts to mount it on the passenger side. I have had it mounted with the jack mechanism either inside or out. I think I have it on the inside now, this way it will sit lower and will reduce the risk of "hooking" on to something.
FJVP said:
I mounted mine on the rear....Since I'm am not the tallest guy in the world, I wanted to be able to stand upon the rear and unload it without much laboring.
Mounting from the rear is a good thing right? ;D ;D ;D
haha Tim, how do you get up on the rear? Do you use a step stool to mount the rear and they don't like it when you unload without laboring!!!! ;) ;D ;D
Kokopeli said:
Tim, you may be small in size, but to us you are a giant amongst men.
Thanks Brian....That was kind.
Butt of course! ;D
I figured someone was gunna crack a joke (pun intended)!
· NOT a moderator!
I mounted mine on the passenger side because of weight and safety. If i have to pull over and change a tire on the side of the road, I want to spend the least amount of time as possible on the traffic side of the car so the jack being on the passenger side keeps me off the traffic side while removing and replacing the jack.
But what I want to know is why does everyone but me mount their hi-lift upside down? The handle is supposed to be on top!
· NOT a moderator!
mine is back on the drivers side but it is handle side up :)
And you shall now be applauded! Oh wait, no clapping hands smilyey so.... :) clap clap clap :) that will have to work!
1 - 12 of 12 Posts
