Can someone help me get this right? I just got a new firestik wire and antenna and I just cant seem to get my swr below 2, sometimes below 3. I hope its not my radio that is damaged. thanks
Check the antenna connection...I had to re wire my coax to the connector to the bandi mount because the ground sucked....
Well as far as the ground goes, I scrapped off the paint on the connection area of the bandi mount. What else can I do. They problem really is I am not sure where the problem is exactly.
If you got that connector that is connected to the coax and tightened it to much, it broke the soldered connection. I had the same issue with the walcott set up that was advertised in the blue room....I ended up going to radio shack, buying a new connector, re inserted the coax and fixed my issue.... I was a tuning fool after that. Have had no issues since and it's been over a year.
Yea I heard of that, so I made sure not to tighten it too much, Actually I think its a little loose, not sure exactly what the torque should be but I made just enough to feel solid. But I have a feeling it may be my radio, because I am getting different swrs with different radios.
I am in laguna hills, Nellie gail to be more specific. I am free today, tommorow before noon, later permitting I dont get called for jury duty. Westminister seems kind of far, But I guess I can make the drive, though with this rain I may try it later. Thanks for the help!
Busta, i live in the same area as you and the drive for Steven to help is always worth it.
Discussion Starter · #9 ·
Id love his help, I just think I am gonna wait out the rain, as far as freeway driving goes, people here are crazy when it gets wet.
WORD!
I was running around all day and tryin to get home there was an accident in both directions on the 5, 15 and 805. I was stuck in Chula Juana for hours. I did find TONS of road puddles though. best wat to get around traffic is drive through the blocked off flooded areas. lolz
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
