HOPE THIS HELPS YOU OUT
Last Modified: 7-9-20106.4 C
Model Year: 2008
Model: FJ Cruiser
Doc ID: RM0000023XQ001X
Title: BRAKE CONTROL: VEHICLE STABILITY CONTROL SYSTEM: C0210/33,C0215/34,C1238/38,C1239/39,C1273/73,C1274/74,C1277/77,C1278/78: Rear Speed Sensor RH Circuit (2008 FJ Cruiser)DTC
C0210/33
DTC
C0215/34
Rear Speed Sensor LH Circuit
DTC
C1238/38
Foreign Object is Attached on Tip of Rear Speed Sensor RH
DTC
C1239/39
Foreign Object is Attached on Tip of Rear Speed Sensor LH
DTC
C1273/73
Low Output Signal of Rear Speed Sensor RH (Test Mode DTC)
DTC
C1274/74
Low Output Signal of Rear Speed Sensor LH (Test Mode DTC)
DTC
C1277/77
Abnormal Change in Output Signal of Rear Speed Sensor RH (Test Mode DTC)
DTC
C1278/78
Abnormal Change in Output Signal of Rear Speed Sensor LH (Test Mode DTC)
DESCRIPTION
.DTC Detecting Conditions
Trouble Areas
C0210/33
C0215/34
When any of following conditions detected:
- At vehicle speed of 6 mph (10 km/h) or more, open or short in sensor signal circuit continues for 1 second or more.
- Momentary interruption of sensor signal from abnormal wheel occurs 255 times or more.
- Open in speed sensor signal circuit continues for 0.5 seconds or more.
- With IG1 terminal voltage 9.5 V or more, sensor power supply voltage decreases for 0.5 seconds or more.
- When vehicle driven at speed of more than 10 km/h (6 mph), one of wheel speeds below one-seventh of other wheel speeds for 15 seconds or more.
- Rear speed sensor
- Rear speed sensor circuit
- Sensor installation
- Skid control sensor wire
- Master cylinder solenoid (skid control ECU)
C1238/38
C1239/39
When either of following conditions (1 or 2) detected:
- At vehicle speed of 12 mph (20 km/h) or more, noise in speed sensor signal continues for 5 seconds or more.
- At vehicle speed of 6 mph (10 km/h) or more, noise detected as rotor turns, for 15 seconds or more.
- Rear speed sensor
C1273/73
C1274/74
Detected only during test mode.
- Rear speed sensor
C1277/77
C1278/78
- Rear speed sensor
WIRING DIAGRAM
INSPECTION PROCEDURE
NOTICE:
- When replacing the master cylinder solenoid, perform zero point calibration
- Check the speed sensor signal in test mode after clearing or replacement
PROCEDURE
CHECK HARNESS AND CONNECTOR (MOMENTARY INTERRUPTION)
(a) Connect the Techstream to the DLC3.
(b) Turn the ignition switch to ON.
(c) Turn the tester on.
(d) Using the Techstream, check for any momentary interruption in the wire harness and connector of the speed sensor.
Select the following menu items: Chassis / ABS/VSC/TRAC/ Data List
DATA LIST: ABS/VSC/TRAC
Tester Display
Measurement Item / Range
Normal Condition
Diagnostic Note
RR Speed Open
RR speed sensor open detection: OPN_DET or NORMAL
OPN_DET: Momentary interruption
NORMAL: Normal
RL Speed Open
RL speed sensor open detection: OPN_DET or NORMAL
NORMAL: Normal
There are no momentary interruptions.
HINT:
Perform the above inspection before removing the sensor and connector.
CHECK AND REPLACE HARNESS OR CONNECTOR
READ VALUE USING DATA LIST
(b) Start the engine and drive the vehicle.
(d) Select the following menu items: Chassis / ABS/VSC/TRAC/ Data List
Tester Display
Normal Condition
Diagnostic Note
RR Wheel Speed
Wheel speed sensor (RR) reading : min.: 0 MPH (0 km/h), max.: 202 MPH (326 km/h)
Actual wheel speed
Similar to speed indicated on speedometer
RR Wheel Speed
Wheel speed sensor (RL) reading : min.: 0 MPH (0 km/h), max.: 202 MPH (326 km/h)
Actual wheel speed
(e) Check that there is no significant difference between the speed value displayed on the Techstream and the speed value displayed on the speedometer when driving the vehicle.
There is no significant difference in the displayed speed values.
HINT:
There is a tolerance of +- 10% in the speedometer indication.
REAR SPEED SENSOR INSTALLATION
PERFORM TEST MODE INSPECTION
(a) Perform a TEST MODE inspection and check for DTCs
REPAIR OR REPLACE HARNESS OR CONNECTOR
RECONFIRM DTC
(a) Clear the DTC(s)
(b) Start the engine.
(c) Drive the vehicle at a speed of 12 mph (20 km/h) or more for at least 60 seconds.
(d) Check if the same DTC(s) is output
Result
Proceed to
DTC not output
A
DTC output
B
END
5.
CHECK REAR SPEED SENSOR INSTALLATION
(a) Check that the speed sensor installation bolt is tightened properly.
OK:
The installation bolt is tightened properly.
Torque:
8.0 N·m (82 kgf·cm, 71in·lbf)
TIGHTEN BOLT PROPERLY
(a) Visually check the speed sensor for deformation and damage
No deformation or damage.
There is no gap between the sensor and rear axle carrier.
REAR SPEED SENSOR
INSPECT SKID CONTROL SENSOR WIRE
(a) Disconnect the rear speed sensor wire.
(b) Measure the resistance.
Standard resistance (LH)
Tester Connection
Specified Condition
X2-2 - OX1-1
10 kΩ or higher
X2-2 - OX1-2
Below 1 Ω
X2-2 - OX1-3
10 kΩ or higher
X2-2 - OX1-4
10 kΩ or higher
X2-2 - Body ground
10 kΩ or higher
X2-1 - OX1-1
Below 1 Ω
X2-1 - OX1-2
10 kΩ or higher
X2-1 - OX1-3
10 kΩ or higher
X2-1 - OX1-4
10 kΩ or higher
X2-1 - Body ground
10 kΩ or higher
Standard resistance (RH):
Tester Connection
Specified Condition
X1-1 - OX1-1
10 kΩ or higher
X1-1 - OX1-2
10 kΩ or higher
X1-1 - OX1-3
Below 1 Ω
X1-1 - OX1-4
10 kΩ or higher
X1-1 - Body ground
10 kΩ or higher
X1-2 - OX1-1
10 kΩ or higher
X1-2 - OX1-2
10 kΩ or higher
X1-2 - OX1-3
10 kΩ or higher
X1-2 - OX1-4
Below 1 Ω
X1-2 - Body ground
10 kΩ or higher
REPLACE SKID CONTROL SENSOR WIRE
CHECK HARNESS AND CONNECTOR (SKID CONTROL ECU - SKID CONTROL SENSOR)
(a) Disconnect the skid control ECU connector.
(b) Disconnect the rear speed sensor connector
(c) Measure the resistance.
Tester Connection
Specified Condition
A4-20 (RL+) - X2-2
Below 1 Ω
A4-6 (RL-) - X2-1
Below 1 Ω
Tester Connection
Specified Condition
A4-5 (RR+) - X1-2
Below 1 Ω
A4-19 (RR-) - X1-1
Below 1 Ω
CHECK SKID CONTROL SENSOR (INPUT VOLTAGE)
(a) Disconnect the rear speed sensor connector.
(c) Measure the voltage
Standard voltage (LH)
Tester Connection
Specified Condition
X2-2 - Body ground
5.7 to 17.3 V
Standard voltage (RH)
Tester Connection
Specified Condition
X1-2 - Body ground
5.7 to 17.3 V
MASTER CYLINDER SOLENOID
10
RECONFIRM DTC
(a) Clear the DTC(s) <A href="(b) Start the engine.
Result
Proceed to
DTC output
A
DTC not output
B
END
11
REPLACE REAR SPEED SENSOR
(a) Replace the rear speed sensor
12
RECONFIRM DTC
Result
Proceed to
DTC output
A
DTC not output
B
END
