Inconsistent crack no start issue.
2498 Views 4 Replies 3 Participants Last post by  Free4pf
I I have a 2007 FJ manual trans four-wheel drive. It will start two or three times then I will experience a crank no start issue. I take out the fuse for the ECM put it back in and it will start again two or three times and then it will experience the same issue. It's not popping any codes in the computer. I can only assume there is a sensor of some sort that resets when I pull the fuse and put it back in. has anybody experienced anything like this.
Did you get it figured out? Might look at ground wires, chewed on wires, clutch switch? Curious what could be intermittent like that.
I haven't figured it out yet and I've had a shop for two weeks they say they're having issues figuring it out because it's not tripping any codes and it's super intermittent
Following thread I’m having the same issue
As soon as I have it figured out I'll let you know. This has been driving me nuts for over a month
