1 - 6 of 6 Posts
I finally put my horns on today, I just bolted em to the top of my roof rack. looks real ******* but I like it. 2 things though. the first time I honked it I blew the 10 amp fuse. after that i disconnected one of my other horns, the OOgahH, popped in a 15 amp and seems to work fine now.
the second thing that worries me is I have them facing forward so I'm wondering if I need to have plugs in them if it rains. I think I'm definitly gonna put some screen on them to keep beez and other flying things out.
HAHAH, all in good time, I pick up my camera tomorrow so I can take real photos instead of the video camera grainy stills i usually post up. looks kinda like this, only 3 chrome horns aannnd not a semi.lol.
OK heres some pics. a couple different angles.
Since I dont have onboard air yet I'm just running the little stock compressor that comes with em. I mounted it to the underside of the rack below the horns so its less obvious. then I ran a solid core wire 12g from the second horn outlet, across the engine bay, then tucked it behind the door trim, ran it up, and bent it to fit in the channels between the panels and the roof. good thing about solid core wire is it holds its shape. then I ziptied the rest, and ran the ground directly to the roofrack mounting bolt.
heres a pic of the wire
1 - 6 of 6 Posts
