1 - 20 of 61 Posts
Discussion Starter · #16 ·
I'd like one- can these be installed even without the old plastic?
It can be installed without the old plastic, however, there are only two studs on the floor that it mounts to. It might not be sturdy with just the two mounts. What you might be able do is drill a 1/4" hole where the third post is and put a bolt up through from the outside in to make a third stud. Then it should be very stable.
Automotive lighting Automotive design Automotive exterior Rectangle Motor vehicle
1 - 20 of 61 Posts
