FJVP said:Do they bolt to the hub and then the wheel bolts to the spacer?
There are many that are running spacers, including me. Some have offroaded them very hard and they have held up well....Kokopeli said:I like the look when the tires stick out and it will help your stability as well.
Before I bought my OME stilts and shoes (lift and tires), I was discussing options with my buddy who works with 4 Wheel Parts. He was against putting spacers on Toyotas because "Toyotas have weak hub assemblies". Has anyone had any issues using spacers on their FJ, off road or otherwise?
Also, by putting on the spacers, do you still need to do the body mount chop if you run 305s?
Thanks for the post Oscarr!
~B
Kokopeli said:Also, by putting on the spacers, do you still need to do the body mount chop if you run 305s?
~B
