UPDATE 11/28/2014 :
The application for the test is now available. Last day to apply is 12/11/2014.
http://agency.governmentjobs.com/lacity/default.cfm?action=viewjob&jobid=1014298
One year of high school chemistry, physics, or electronics is all that is needed to apply... Or one semester or quarter at the college level.
More info about the job:
https://docs.google.com/presentatio...tart=true&loop=false&delayms=60000&slide=id.p
This is an entry level job working in a steam plant (power plant). Minimum requirement is a year of high school chemistry/physics/electronics (see the job bulletin for more details). There are 4 plants around LA: Long Beach, Wilmington, El Segundo, and Sun Valley. Full medical and dental for you and immediate family. Pension for retirement.
City of Los Angeles Employment Opportunities
This is where I started out five years ago, it can lead to operations, maintenance mechanic, or instrument tech. Operations works a rotating shift, 10 days on 4 days off (dayshift, then swing shift, then graveyards, then back to dayshift). Maintenance and Instrumentation are on straight day shifts (5 and 2 or a 9/80 schedule). You will work in operations for at least 2 years. After you pass you trainee test you can then apply to go into one of the other disciplines if you want (again after a minium of 2 years in operations).
PDF job description here: http://labrel.ladwp.com/Database/82-85602.pdf
Apply if you qualify, it will take a few months for the whole process from exam to hiring to run its course and the list (of those passing) will be good for at least a couple of years. This exam comes up maybe once every two or three years for a short window of time... don't miss it.
If you have any questions, post them here and I'll try and answer them as best I can.
