Hello all,
I’m new here but have peeked here and there once our FJ hit the 4th gear shudder around 180,000 miles. We purchased our Black Cherry 2007 new when they first came out and have been very happy since. She’s never seen the dealer since we wrote the check so I’ve done all the maintenance since new. Only regular wear items changed out and she is bone stock. Most of the miles have been daily driver for my wife and the only time it’s been in 4x4 is with me running it and rear dif lock to keep it lubed. We have made it to 231,000 miles with synthetic changed every 10,000 and oil filter every other change. After reading up here on the trans shudder we elected to use 4th gear until up to speed around 60 MPH then use over drive if on highway. That got us from 180,000 to 231,000. I did the tranny fluid swap this past weekend via tranny cooler lines at the radiator and it’s like we have a new transmission.
I was planning to swap out water pump, t stat, belt, idlers, hot side of rad, and anything else up front and realized it maybe smart to swap timing chain while at it since we’ve pushed our luck. Is there any history of the life span on timing chain and wether they are worth changing? I have no reason to swap as valve train is normal and no codes.
Thanks for any input regarding the timing chain life span
Tim
