1 - 12 of 12 Posts
2" spacer/adapter needed asap
I need four 2" adapters. 2 would work for now. I just got my new wheels and tires. Let me know what you have. Thanks.
Re: 2" spacer/adapter needed asap
Make sure you check on Blue for that as well. So, 1.5's won't work?
1.5's would mosy likley work. I wanted 2" to be on the safe side.
The wider you go with spacers, the more of an offset you give your rims and tires. With 2" you will almost assuredly rub your tires.
What size tires did you get? Backspacing on the wheels?
Depending what that is, you might have some ridiculoso amount of rubbing at the body mount/fender.
Unique 42-7760 16x7
OFFSET (+/-)MM - 0
BACKSIDE SETTING - 4"
CENTER BORE - 4.2800
285 75 16 terra grappler
I'm running 1" spacers on wheels that have -6 mm of offset and 4" of backspacing. Of course, I'm running 265's. I just wanted a little wider footprint with the lift.
Discussion Starter · #11 ·
Picked up some 1" plates from a machinist shop in Santa Ana. 4wheel parts recomended i give him a call. The 1" worked perfectly! Made of steel, not aluminum ;D
Thanks for all the feedback guys!
1 - 12 of 12 Posts
