1 - 6 of 6 Posts
been searching the blue room and couldn't find an post about this.
but has anyone installed the 115V/400-watt power outlet in the trunk.
my rig didn't come with this option and i've been wanting to add it.
Anyone know the part number and do you need any additional part other than the panel?
Thank you!!!
I read that it's damn near impossible. You'll have to run it off the battery, install heavy gauge wires.... I wanted to do the same thing also.
Also if you install the factory unit it will be VERY costly. It's cheaper to just run a standard inverter like you get at Costco.
X2 you can get a MUCH better 1500 watt inverter that will be extremely more usefull than the 400 stock one. You can pretty much charge a laptop or a cell phone on it, thats about it.
I was about to order a 400 watt inverter off of Amazon since I thought that was the max the cig lighter could run but if it can run more then I'd prefer to get something atleast around 800 watts. Are you talking about connecting it directly to the battery or using the cig lighter?
1 - 6 of 6 Posts
